On board ice machines and ice makers
on board trawler ice machineA range of reliable and durable water cooled ice machines and ice makers designed to work continuously in marine environments. The units are supplied pre-commissioned allowing immediate use once they are installed. Models are available to produce freshwater ice (UBE), saltwater ice (SWE) and StreamIce (SI). For maximum versatility, '3in1' machines can produce all three types from one machine, simply by selecting the desired ice type from the control panel.
Ice machines are supplied complete with their own water cooled refrigeration system and are compact plug and play units designed to be installed quickly and easily. Remote versions are also available where the refrigeration unit and icemaker are separate units, so the ice maker can be installed in once place and the water cooled refrigeration in another.
Ice makers are supplied without refrigeration and must be connected to an existing refrigeration system.
Both chip and scale types of flake ice are available
Stainless steel frame and cabinet for corrosion resistance
Trawler Ice Machines
Plug and play units with refrigeration - simply connect to utilities
We offer two main types of trawler machines, SWE and ZSM. SWE machines are a compact upright design and can be configured to make several different types of ice. ZSM types are designed to make scale type flake ice.
SWE MODELS
Our premier model on board flake ice machines built with a small footprint to take up as litte deck space as possible. These units are highly versatile and can be configured to make any of the ice types below. The ice type can also be easily changed later to a different type should the machine be moved to a boat with different requirements. Please click on a model for further details.
Model
Ice production / 24 hours Dimensions Weight (kg)
flake ice (chip) kg
StreamIce litres
cm (l x b x h)
freshwater
saltwater
Density 25%
Density 40%
750
600
1800
1140
80 x 70 x 141
300
1,000
800
2400
1500
80 x 70 x 141
380
1,250
1,000
3,000
1,900
80 x 70 x 141
380
1,500
1,200
3,600
2,280
100 x 80 x 141
450
2,500
2,000
6,000
3,800
131 x 131 x 141
700
3,000
2,400
7,200
4,500
131 x 131 x 141
1,000
SWE 5.000-2 TW
5,000
4,000
12,000
7,600
210 x 170 x 141
1,400
SWE 10.000-2 TW
10,000
8,000
24,000
15,200
240 x 220 x 141
2,200
ZSM MODELS
ZSM models are designed to make scale type flake ice, TWF types are for freshwater and TWS types are for saltwater.
Model
Output / 24 hours
Dimensions cm (l x b x h)
Weight (kg)
ZSM 1.000 TWF
1,000 kg ice from freshwater
120 x 100 x 100
420
ZSM 2.700 TWF
2,500 kg ice from freshwater
130 x 130 x 130
700
ZSM 5.500 TWF
5,000 kg ice from freshwater
163 x 163 x 130
1,200
ZSM 3.000 TWS
2,700 kg ice from seawater
130 x 130 x 130
700
ZSM 6.000 TWS
5,500 kg ice from seawater
163 x 163 x 130
1,200
Trawler Ice Makers
Icemakers only - requires connection to existing refrigeration supply
SWE MODELS
Our premier model flake ice makers built with a small footprint to take up as litte deck space as possible. These units are highly versatile and can be configured to make any of the ice types below. The ice type can also be easily changed later to a different type should the machine be moved to a boat with different requirements. Please click on a model for further details.
Model
flake ice (chip) kg
StreamIce litres
cm (l x b x h)
  freshwater saltwater Density 25% Density 40%
SWE 750 ET
750
600
1800
1140
300
SWE 1.000 ET
1,000
800
2400
1500
380
SWE1.250 ET
1,250
1,000
3,000
1,900
380
SWE 1.500 ET
1,500
1,200
3,600
2,280
450
2,500
2,000
6,000
3,800
700
SWE 3.000-2 ET
3,000
2,400
7,200
4,500
1,000
SWE 5.000-2 ET
5,000
4,000
12,000
7,600
1,400
SWE 10.000-2 ET
10,000
8,000
24,000
15,200
2,200
ZSM MODELS
ZSM models are designed to make scale type flake ice, ETF types are for freshwater and ETS types are for saltwater.
Model
Output / 24 hours Dimensions (l x b x h) Weight (kg)
ZSM 1.000 ETF
1,000 kg ice from freshwater 75 x 50 x 120 90
ZSM 2.500 ETF
2,500 kg ice from freshwater 90 x 70 x 1450 220
ZSM 2.700 ETS
2,700 kg ice from seawater 90 x 70 x 1450 220
Ziegra Ice Machines (UK) Ltd
Tel: 0844 8808055
Unit 2, Phoenix Court, Hammond Avenue, Stockport, Cheshire, SK4 1PQ
Tel:0844 8808055   Fax: 0161 480 7927   Email: ice@ziegra.co.uk
Specialists in...
Ice Production, Storage, Handling
and Dosing Systems
