Commercial ice machines - 550kg-1,200kg
ice machine with storageA range of high quality ice machines from 550kg to 1,200kg in capacity, which can be purchased on their own, or with any of six different models of ice storage unit.
There are two levels of storage
Level 1. Smartgate. Good hygiene due to the first ice in, first ice out 'smartgate' design, which elimates the stale ice that builds up in the bottom of conventional ice bins. Ice is removed by scoop. Available in two sizes, 500kg and 670kg. Can be paired with a 'smartcart' for easier ice handling. Poly lined for high resistance to corrosion.
Level 2.BK. All the advantages of the Smartgate design, plus the unique gravity feed system that reduces the safety and hygiene risks of manually handling ice. Ice is removed by pulling a handle, which then causes ice to drop into the cart below. the cart is then wheeled to the point of use and the ice scooped out of the cart. Optional totes can be supplied as a set of six which slot into the cart and hold 11kg of ice each for easy unloading of the cart. Poly lined for high resistance to corrosion.
Click on a model to see details
Ice machines only
Model
Output kg/24hours
Storage kg
Dimesions mm (w x d x h)
Weight kg
550
700 x 700 x 850
145
750
700 x 700 x 850
145
1,000
800 x 800 x 850
185
1,200
800 x 800 x 850
185
Ice machines on bins
Model
Output kg/24hours
Storage kg
Dimensions mm (w x d x h)
Weight kg
550
280
1219 x 927 x 2120
240
550
300
1226 x 1007 x 2234
270
550
500
1525 x 984 x 2488
300
700
500
1525 x 984 x 2243
335
750
500
1525 x 984 x 2243
335
750
280
1219 x 927 x 2120
240
750
300
1226 x 1007 x 2234
270
750
500
1525 x 984 x 2488
300
1,000
500
1525 x 1007 x 2638
345
1,200
500
1525 x 1007 x 2638
345
1,000
800
1826 x 1235 x 2689
440
1,200
800
1826 x 1235 x 2689
440
1,000
1,300
1829 x 1416 x 3212
594
1,200
1,300
1829 x 1416 x 3212
594
Ice machines with BK bin and cart system
Hygienic storage option with cart based ice handling system
Standard models are designed for the Smartcart 240 and include the appropriate cart(s).
The 'WB' models have a wider base and are designed to accomodate customers own carts up to 666mm wide.
Model
Output kg/24hours
Storage kg
Weight kg
550
200 + cart
787 x 1226 x 2812
332
550
200
857 x 1226 x 2812
332
750
200 + cart
787 x 1226 x 2812
332
750
200
857 x 1226 x 2812
332
550
400 + carts
1524 x 1226 x 2812
462
550
400
1667 x 1226 x 2812
462
700
400 + carts
1524 x 1226 x 2505
497
750
400 - carts
1524 x 1226 x 2505
497
750
400 + carts
1524 x 1226 x 2812
462
750
400
1667 x 1226 x 2812
462
1,000
400 + carts
1524 x 1226 x 2812
502
1000
400
1667 x 1226 x 2812
502
1,200
400 + carts
1524 x 1226 x 2812
502
1200
400
1667 x 1226 x 2812
502
1,000
630 + carts
1524 x 1226 x 3522
559
1000
630
1667 x 1226 x 3522
559
1200
630 + carts
1524 x 1226 x 3522
559
1200
630
1667 x 1226 x 3522
559
1000
970 + carts
2286 x 1226 x 3462
675
1000
970
2286 x 1226 x 3462
675
1200
970 + carts
2286 x 1226 x 3462
675
1200
970
2286 x 1226 x 3462
675
Ziegra Ice Machines (UK) Ltd
Tel: 0844 8808055
Specialists in...
Ice Production, Storage, Handling
and Dosing Systems
ich
Unit 2, Phoenix Court, Hammond Avenue, Stockport, Cheshire, SK4 1PQ
Tel:0844 8808055   Fax: 0161 480 7927   Email: ice@ziegra.co.uk
Specialists in...
and Dosing Systems
Tel: 0844 8808055
Specialists in...
and Dosing Systems
